What do you do when some smart arse has wrapped his wires around a lug?
Okay so I am trying to re-wire a switch but every wire has been wrapped around each lug so the wires are not coming off the lug and unsoldering is a bitch!
I had to cut cut 2 wires and I am left with the mangled wire around the lugs  :p
  • sweepysweepy Frets: 4190
    Desodering gun ?
  • lovestrat74lovestrat74 Frets: 2530
    sweepy said:
    Desodering gun ?
    Trying but there is little solder left just mangled wire
    Gotcha! Tweezers!!  :#
  • ICBMICBM Frets: 72500
    It could be worse - it could be a Fulltone where they've covered the whole top of the switch in resin, and made the wires so short you can't cut them and have them reach the new switch. Twats.
  • stickyfiddlestickyfiddle Frets: 27138
    Some combination of tweezers, needle-nose pliers and a small pointy thing are your friend here.
  • RolandRoland Frets: 8733
    Try a spike to loosen the turns of wire, then grab it with needle nose pliers.
  • FunkfingersFunkfingers Frets: 14511
    This works. Eventually. Have patience.
