Hi there,
Random question of the day! LOL!
My guitar has a 2 degree neck angle (the angle of the neck as it leaves the body). So the strings will leave the bridge at a 2 degree angle.
I've made my pick up routing jig, but wondering about how the top of the pick up will present to the strings. I.e. if the pick up cavity is flat, the top of the pickup face will not be parallel with the strings.
i.e. would you make a 2 degree angle in the top of the pickup routing jig so that when the pick up sits into it, it is effectively parallel with the strings? Does that make sense?
The routing jig is super tight with the pickup size, so there is no room to wiggle an angle if i routed it square with the body.
Anybody any thoughts or experiences to share?
Great idea, though, that I've not seen before.
But aesthetics matter .
It's shallower than 1 in 28, so if your humbucker is one inch wide, the strings are less than 1mm further away on one side than the other. I still think that is too small to notice, but obviously YMMV.
The angle the pickup sits is determined by the angle the spring and adjustment screw hold the pickup face at ... not by angle of the rout! That is in it's turn determined by the 'slope' of the face of the pickup mounting rings.
The angle would be determined by the bottom of the cavity only if the pickup was body mounted ... and then you change the pickup angle with a 'wedge cut' foam pickup cushion.
Personally I would never rout a pickup cavity as tight as you have indicated. Pickup bobbin sizes, cover tolerances vary ... and if you ever want to change pickups you may be stymied.
The angle of the pickup face will make bugger all difference to the pickup sound anyway … unless you are a member of the My Paul Forum and can hear the tin content of solder!
