Glad iI'm not the only one to wonder.
As for the pedals needing to have more output at higher volume, I've never heard an adequate answer, but the one which makes the most sense is that your guitar's output isn't increasing like your amp's output, so you need to give your signal a bit of a shunt.
If you set the pedals up for drive with the master volume and controlled the amp's volume with the preamp volume, you'll probably not need to mess with the pedals so much.
It'd be loud though.
I suspect it's possibly something to do with our ears, as @chrismusic alluded to. But I've no idea, it is bizarre.
