I've bought the Echo Blue Delay pedal kit from Poodle Pedal Parts Emporium. I think I may have been a bit ambitious for a first build but I don't need any extra drive pedals( I have a Marshall UK made Guv'nor and a Joyo Sweet Baby).
I've done some soldering before (A Level physics and some electronics at Uni, and the odd bit around the house) and have a nice fine-point soldering iron. My solder is pretty old (I must have had it well over 25 years) flux cored and with added lead for extra sparkle! I've also got a fairly basic multi-meter but I the display is a bit dodgy and you sometimes have to have an educated guess at the numbers it's trying to display, and one of those weird angle-stand devices with crocodile clips and a magnifying glass to act as an extra pair of hands.
Anyone got any tips on building either this pedal, or pedals from this supplier, or indeed general building tips. What kit am I missing? What do I need to know that aren't in the instructions?
I watched a guy build a fuzz kit from Poodle on YT and it seemed straightforward but he put all the resistors in first, then the capacitors and so on. I think I will try to work from one edge, putting everything on the edge in, then move in a little bit. That would seem to me to give me the most room to manoeuvre as the board gets more and more populated. Does this seem reasonable or am I missing something?
Anybody know whether the silver end of the diode goes in the square hole or the round one?
I've emailed Pedal Parts so hopefully I'll get an answer back tomorrow, but if anyone knows I'll be able to crack on sooner.
Cheers,
Dean.
This document clearly shows the band on the square pad: http://pedalparts.co.uk/docs/EchoBlue-v2.pdf
