Do you want more gain/comp/saturation or just more volume? If you've got a lot of pre-amp gain going on you won't get much more volume out of the front end.
FWIW I boost my amp with a TS9 and use a T-Rex Twin Boost in the fx loop for more volume. I've used a Boss EQ, EHX LPB-1 and a SHO clone in a similar fashion in the past and they've worked fine too.
You are likely going to need to compromise here just by nature of an amp with no FX loop.
Funnily I would have suggested a Bad Monkey.
Maybe something like a SD-1, with the gain low, and the volume set for a boost.
Although I do like the MXR Distortion 3. Even though I think Rev isn't a big MXR fan.....
How about increasing the gain on the amp, then stepping on a volume box - literally a pot in front of the chain. When on, it'll reduce the volume to rhythm gain, then turn it off for gain and volume.
