Closest would be 2 DD-6*'s one reversed, one straight.
*or similar
Could something like a G3 do what you're looking for?
IE set 2 (or more) delays into one patch, and switch them on individually.
Could a DD-20 do what you want?
I happen to be selling one too. Just in case you or anyone else is interested.
I wouldn't need them separately switchable, but would need tap tempo.
Anyway I was just musing on the near non-existence of it in a single pedal. Thinking about it, it's not too disimilar to the standard 'dual delay' algorithms you get. It's just one of the buffers needs to read left and one of them needs to read right!
Wouldn't it be much simpler if you just learned to play the fucking parts properly rather than relying on gimmicky effects you big douchebag????
http://i1284.photobucket.com/albums/a579/imadray/BigLebowski_zps4b5abf5d.jpg
By at the same time would, do you mean exactly at the same time so the delays would only be repeating the original signal rather than one also repeating the previous delay?
