The issue is the amp is making a sound in standby. I thought it can't do any harm to try switching the valves, as it's no bad thing having a back up set.
My band, Red For Dissent
JJs are the best currently available EL84s for reliability, and do sound darker than most other brands.
I would get a set of these - it's always worth having a spare set of power valves, plus the correct fuses - and try them. If it doesn't fix the "problem", just leave whichever ones you like the sound of best in the amp and keep the others as spares. And stop worrying about it .
The amp also does ideally need biasing - unlike many EL84 amps it's not cathode biased - and again if there is no adjuster on the outside (since there doesn't seem to be a sensing resistor or test point) you will need to do that from the inside.
Given the way a lot of modern amps seem to be designed deliberately to be non-user-serviceable, it wouldn't surprise me!
But, since it's probably running fairly conservatively by EL84 amp standards given the range of bias voltage listed on the schematic, it's unlikely to be critical and is safe enough just to put new valves in.
