Most likely due to a faulty power valve or rectifier.
Once you've identified it and replaced whichever one it is, you really should put an F in since that's what's specified.
There are shops which seem to make a habit of this sort of thing.
I very much doubt it came with the wrong fuse type from the factory. I think that would be a breach of regulations, as well as extremely unlikely to happen since the assembly line will only have the correct fuses - the worker won't have a box of different ones to choose from.
My guess is that the rectifier valve has an intermittent arc fault - this is common - and that it doesn't normally do it unless you switch on with the standby off. But it could, probably when you crank the amp up. So I would be inclined to change the rectifier valve as well, especially if it's a Sovtek - which Fender do use and which seem to have the worst failure rate like this.
