Some folk's definition of "perfect" and "mint" differ greatly from mine!
Dave.
"Nobody is really researching robot jokes"
Having had a closer look at the pics the description is bollocks too. Zoom in on the 7th pic, the one of the inside of the chassis.
ICBM is dead right re Mustard caps, although as a working amp like my DR103 yopu'd need to do this- not consistant with description.
One of the transformers has deffo been replaced or rewound. It doesn't look like an original Partridge looks.
I emailed him- repsonse below:
This was bought by me directly from Hiwatt in 1975. It has been in my possesion ever since and no work other than what I describe has been done.
Both transformers have the "Partridge" label on them.
So what! One has clearly at least been repaired.
It's very unlikely you would need to change any of the original Mustard caps either - they fail very rarely, and usually only one or two. So they have been removed either by someone who doesn't know that a 'cap job' means the electrolytics - which doesn't make sense since the main filter caps have *not* been replaced, apart from the one which has been bodged - or someone who wanted to steal them.
You are welcome to your opinion but I do know the history from the time it was delivered to my shop by Hiwatt.
Regards
So my response (paraphrased from ICBM and the DG Gear Forum) was this:
n that case I have to report this as a fraudulent listing- it's not mint and it's certainly not perfect. The filter cap job is relatively recent (botched too) and half the electrolytic caps on the board weren't produced in 1975.
Why is there white tape over the power tranny if it's not had a rewind?
I'm happy to shove this on the Vintage Amp Forum and ask experts like Mark Huss and Clayton to chime in- they're world experts.
To ask a decent price for a cosmetically good amp (which the outside is- the chassis is browned) is one thing- to big up the description when it's clearly not what you claim is another.
Some of the soldering is also clearly new- and really poor as opposed to Harry Joyce's team- they'd literally inspect every joint under a mag glass.
You said I'm entitled to my opinion- that's a defensive stance bearing in mind my views are both informed and plausible. If you had the integrity you claim you'd engage and ask more. SA212's are few and far between- and there's a lot of people who know every solder joint of a Hiwatt and this has had a lot of work done on it.
I'm happy my chassis passed your inspection.....
(my Kenneth Williams pun of the day...!)
Nope- toggle - although if you have a brain you'd bypass this and hard wire through into 240v save frying it.
They sound nothing like a DR103 by the way- far less headroom and nothing like the projection
It's a very minor issue next to the bodged cap job, missing Mustards and dodgy PT repair anyway!
