Got myself in a little wiring tangle let's say and any advice on what I have cocked up on would be appreciated.
In the end I did decide to change the pickups on my Explorer to a certain set, using the 2 conductor braided wire. I'm not the best on wiring but gave it a go, following the pictures I had taken of one of the SG's I had which had pretty much the same configuration, 1 volume, 1 tone, pickup selector and braided wire pickups.
After doing it all, predictably I have made some sort of error, most likely and hopefully small, but still a cock up is a cock up. Basically the bridge pickup works fine, but when in the neck or using both I get no sound. I have done a diagram of how it is and hopefully this will show the mistake I have made that I don't know of.
Any help appreciated here, feel free to take the picture and edit it. If it is ok as it is then maybe I have a bad solder joint somewhere.
