The Metal Muff is wired to the Chill Switch so it can be added in short bursts or held for an intro.
The Vox Tonelab does all the modulations, wahs and delays and does a perfectly good job too - I want to see if I can get a Tele-into-AC15 sort of tone out of it at some point, but otherwise it's good.
The Rainbow Machine does weirdness, not sure where it fits in yet, but I like it
There's also an RC-50 just out of shot which I'm going to try and use without ending up unable to gig without it - it's a great bit of kit but because I can write backing loops and save them to it I might end up too dependant, we'll see.
the expression pedal certainly adds to the wackiness available from the Rainbow Machine, I'm sure I'll find some useable noises eventually !
The Expression pedal definitely adds a lot to how much mess you can get into, which in this case is a good thing !
