Yes I agree, small differences in component values can change the tone dramatically.
I'm looking at the schematics, I think the treble control between the two opamps was an original Timmy idea by Paul Cochrane.
Zendrive
Timmy
This was merely an exercise in electronics and fitting a Timmy into a 1590a ( the fuzzdog Zendrive PCB fits in one ... and so will the Timmy PCB it appears.)
Now I've just got to figure out how Mr C gets that amazing finish on Timmys
oh and are the transistors being used as transistors in the Zendrive?
Essentially both of them are Tube Screamer overdrive with Rat filtering and variable bass control (fixed on the Rat).
I'm confused, the Rat only has one opamp, so how can the Rat have as I stated "a treble control between the two opamps" like a Zendrive, I've experimented and built both circuits a few times. The Rat is single Opamp the Zendrive is a dual Opamp.
The bigger difference is that the Rat uses clipping diodes to ground after the first gain stage, whereas the Timmy and Zendrive have them in the NFB loop like a Tube Screamer. So in concept (if not detail) they are both a "Tube Screamer with Rat filtering". The TS uses the second op-amp stage as a tone control instead.
