I've had less success on other guitars. I tried loads of combinations of capacitor alone / capacitor+resistor in parallel / capacitor+resistor in series on my Gretsch jet which turned to utter mud as soon as I used the volume control but without any success (still too muddy).
There are so many variables in this - pickups, pots, guitar wiring scheme (Gretsch uses a master volume) that I think the only solution would be to hook up different value components to find the right ones for your guitar. There's a great YouTube vid on this where the chap uses leads and alligator clips to audition different capacitors - particularly useful with a semi acoustic as the hassle of removing the pots to swap out components is hellish:
The neck pickup cap value is less sensitive IME, you can go quite high on it without brittleness, I like 470pf for an almost Stratty tone.
50s wiring on the bridge pickup doesn't completely prevent treble roll off when you lower the volume but it's not muddy, it's warm but still detailed. The tone pot suddenly becomes useful too, with the volume lowered a little the tone starts to scoop some of the upper mids away before it kills all the top end. Loads of cool sounds in there!
It's all personal preference obviously, but my guitar is well balanced, versatile and natural sounding.
