first chord you play when you pick up the guitar?
John_PJohn_P Frets: 2750
(apologies if this is in the wrong place - it seemed the closest to be about general playing)
So when I first grab a guitar - say at a soundcheck or to practise -  years ago it would be a clean open A2 (X02200) or a ringout  Dm with open A & E strings  (X07760)
Now I hit a high gain sound and play a D power chord with added low A   5577XX
Does everyone else have a set first chord or is it random?
  • Generally a G major 320033.
    I like the sound and easy to tell which string (if any) is out of tune.
    PSN id : snakey33stoo
  • siremoonsiremoon Frets: 1524
    For no logical reason it's always a D major.  Just a habit I've picked up for some reason.  :)
    “He is like a man with a fork in a world of soup.” - Noel Gallagher
  • benvallbenvall Frets: 83
    Me too
  • An open B7 down at the nut closely followed by 'I woke up this morning...' :-D
  • stickyfiddlestickyfiddle Frets: 27078
    I'm another open D guy, but usually x.x.0.7.10.10
    I like inversions :)
    Drop-C... and a miserable bugger, so it's usually 000231, low to high.
  • SporkySporky Frets: 28358
    133555
  • monquixotemonquixote Frets: 17630
    Hammer into an Em7 for clean, or hit an open A and pull off C to A.
  • mike_lmike_l Frets: 5700
    edited August 2013
    Usually a quick noodle in Em around the 12th fret.
    Then E5 at the 7th fret.
    Or an open Dsus2.
    No real reason for any of the above
    Then quickly check my tuning, with my tuner pedal.
    Then crack on with whatever I'm trying to learn.
    G for me.
  • bigjonbigjon Frets: 680
    Me too
    Me too except with the 320003 voicing
    E7#9 or A13
  • ChuffolaChuffola Frets: 2026
    Hendrix chord for me.
  • digitalscreamdigitalscream Frets: 26620
    I'm usually in drop-Db, so it's got to be 000230. Picked and jangly for clean, "da-da-daaaaaaaaaaa" with distortion...
    <space for hire>
  • I normally use a tuner so I tend not to bother with listening for out-of-tune strings as I expect them to be in tune if I've just checked 'em. After that, it's often a descending dominant arpeggio in a blooze-kind-of-way usually for checking the sound - for volume, mainly ... if I have my pedalboard full of toys I've usually adjusted the pots on each toy so they're at their default positions so I often don't need to check the right amount of boost, chorus, overdrive etc
  • holnrewholnrew Frets: 8207
    022 power chord, to check the tuning of the bottom three strings as they tend to be the ones that are out. Then I move down to an A Minor to check the rest.
    My V key is broken
  • I've never thought about it before, but I definitely do have a go-to first chord. Straight up vanilla A major x02220. I'm not sure what that says about me as a guitar player (or a person).
    There's something about the fist grip that just makes it feel like the natural thing to do when I grab a guitar neck.
    Loved reading everyone's replies here. Who knew so much strategic thinking could go into that first strum...?!
    A full E-chord for me .. let's me know if the guitars in tune.
  • Hendrix chord for me too. E7#9 is it called?
    x 7 6 7 8 x type effort.
    or sometimes I go for x 7 6 7 7 7
    No idea why. Probably cos our bassist is usually set up and soundchecking before me so I use a funk chord to lock into what he's playing.
  • Open A to G every time!
