I know I want one.
I like the super doomy chord stuff they do.
I like the singing lead tones you get a la Gilmour and John frusciante.
I suspect that all three of these sounds are going to be different muffs. There are loads!
Of interest:
IC big muff. Clones are available so I won't have to pay through the nose for an original. And it might be more reliable.
Russian
Nyc
Others?
I think the fru lead tone comes from a ds-2 and a big muff, running one into the other. It's quite different to the Gilmour tone, which sounds more like just a muff with delay.
The doomy stuff is like letting a big wet fart out. Really satisfying and leaves a lasting impression.
Tips?
I'll look into the swollen pickle, too. What a vile name for a pedal
http://www.youtube.com/watch?v=zAotpk1Tl4M&list=UUZnf3mdsauHpQu7Txmrf8ww
Also, I've just read a review in Guitarist mag of a new Deluxe Big Muff from EHX - bass boost, footswitchable semi-parametric mid boost, gate and attack controls. Might give you the flexability you're after?
Yeah, I've seen that - I'm scared of buying an ehx though because they just break. I quite like the flexibility, and could probably change out the jacks and the switch myself...
Muff with a mid hump switch. Made for the Gilmore sound.
There's one in the classifieds. Ahem!
Good job you warned me off EHX in my recent thread about EHX pedals, then.
OH WAIT, NO YOU DIDN'T
(Just kidding, I knew going in that they didn't have the best rep for reliability, but I need them to be small, and I have Thomann's 3 year warranty if I'm stuck ) )
Why do people go for fuzz and not all-out full overdrive? Not saying they shouldn't, mind, it's just that to me fuzz sounds like OD with the drive turned down to tasteful levels. Nice work Monkey by the way. Love the speed up and solo on PTFM.
The ICBM is probably the most consistent muff, but it also sounds quite a bit different to the 'regular' muffs. Great if you're after that Smashing Pumpkin sound though.
As for which ones do Gilmour. His number 1 muff, using a bit of logic and deduction, is likely similar to what we've designated the DGM3 on the sheet. I can say that it sustains for days and has that sound. For doom, build our UltraStoner, it's the daddy. http://juansolo.co.uk/stompage/Muffsv2.htm
This is why I needed this thread.
If you listen to John frusciante solo tones on slane castle and any tour since, it pretty much always sounds like either a muff into a ds-2 or a ds-2 into a muff.
So I guess I'm after one that can do the gilmoury lead tone, because I can then push it for the bonkers forever sustain that fru uses.
Just had a look at your sellage page. Sadly, the ICBM doesn't look like the one for me? shame.
You do have one or two others though, how do they stack up?
Yeah, definitely won't be able to afford a Pete cornish! Nor a Hiwatt...
I'm more looking for that ballpark sound - it's different to the frusciante sound, but something that let's me approximate that singing sustain will be good enough.
I'm going to ask @juansolo if any of his fuzz pedals for sale would get me close enough.
If not, I'll keep an eye out for a rat, too. I confess I've not used one for leads before, I've always used it for really chunky rhythm sounds and fuzzy od tones.
Yeah the ICBM ain't what you're after and impmann is absolutely right to get Gilmour, some stackage is required.
