Hi folks,
Loving the new forum - looks great. great job, well done and thank you to all those who made it happen.
Quick question regarding attenuation on my jtm45ri.
I could do with just taking it down a notch in certain circumstances. I'm not talking gig levels down to bedroom levels -far from it, just loud gig down to quieter gig for smaller venues and when playing with our very light handed female drummer.
I'm playing into a 16ohm cab. If I was to make a 16ohm load just from, say, a 100w resistor and run that in parallel with the cab (setting the amp output to 8ohms) would it:
A) work and be safe for the amp?
have a noticeable impact on the Volume of the amp at a given setting?
Hope that makes sense?
Cheers
They have a good website with clips.
I bought one to try and tame an 18watt head for home use but it didn`t cut enough volume for
that scenario.
hth.
Maybe borrow a HotPlate for your next gig and try that at the -4dB and -8dB settings. This forum software doesn't show location during browsing, so I don't know where you are, but if you're near Cambridge I can lend you mine.
