So, I'm looking at an attenuator dummy load thing that has the option to attenuate to 5%, 3%, or 1% power. So on my new Pro Junior, a 15 watt amp, quick basic maths tells me that's 0.75w, 0.45w, and 0.15w respectively.
Firstly, is that right to assume as a sum?
Secondly, for bedroom playing, what does this mean for volume? Clever folks can answer in decibels etc which would be interesting, but essentially my puny brain would work well with an answer like "a bit louder than acoustic guitar volume" etc. I plan to push the PJ pretty hard
Thanks
you push the amp .
soundcloud.com/thecolourbox-1
It will be through the combo speaker yes. If I can get a nice sound at acoustic guitar volume that would be great. I'm not unwilling to compromise a bit of loss soundwise as long as its quite good
The volume on 2 at the mo is a nice level of volume, but I'm fairly sure the volume knob is not fully linear!
I got some lovely Vox-ish chimey overdrive out of the PJ at very civilised volume levels using a home made L-pad and a Tubescreamer set almost clean. Think Coldplay's Parachutes album and you're pretty much there.
Unfortunately without an attenuator there's no way I'll get past 2 on volume at home, which is a nice clean but not what I want the amp for
The point I'm really making is that you don't have to drive the PJ that hard to get some great tones, which also means that you may not need as drastic a level of attenuation as you may think.
A PJ set halfway being hit by a fuzz pedal is awesome for Jack White type stuff, and I think a cheap L-pad should easily bring the volume down enough.
I know what you mean and appreciate your Devils applecart, but I've tried the pedal thing for ages and it just sounds like I'm using an amplified pedal (which of course I effectively am). I also find that getting the balance between the two core sounds I use (overdriven and fuzz) much more difficult
The times when I've best found that balance and had a sound I like, it's come from boosting the amp, then having the fuzz between the two and switching on and off. Then for overdrive I have a boosted amp, wang on the fuzz and the booster boosts that instead and we're all happy.
Just played it on low with a cheap but good Joyo Sweet Baby, but just doesn't do it for me as I feel I could just have any old amp to do that and it sounds the same
