I have a Seymour Duncan Woody XL on my Texan and tomorrow night I may have to go to an open mike night as part of our works xmas party
How do i make it work through a PA?
^ they'll frequently have a guitar they can lend you too in my experience.
There's no getting out of serenading the office cougars matey.
No guitars at this place - it's glorified karaoke
Probably would if she had a clue. ICBM may be right- your passive pickup may not have the juice to send a healthy signal to a PA system. If they can jack the input gain right up it might work, but might just introlduce so much background noise that it's not worth it. A DI box is the way to go, but it's probably too late to buy one now.
Worst case, if they have two mics you can point one at your gob and the other one at your guitar and make sure to stand really still.
It doesn't entirely replace a DI box because the output is still not balanced, so you may get hum if it's a long way from the pedal to the mixer, but in most other situations it will work. It has an input impedance of 1Mohm so it's OK with piezos. (10M is better but you will need a dedicated acoustic preamp to get that.)
As far as I know most other buffered pedals have an impedance of at least 500K, which is fine for magnetics and usable for piezos, even if a bit too low.
Even an unbuffered pedal will usually work if it's something you can leave on all the time, ie not a distortion!
