Anyone getting a good lead guitar sound recording at home?
I quite like the sound that I get out of my amps when playing at low volumes (Blackstar ID60, H&K switchblade, Axe fx mk1), but they never sound as good recorded. I’ve tried a (not particularly amazing) mic and it wasn’t great.
Tried Guitar rig (way too hissy)
Tried axe fx direct into computer, probably best of the lot, but still not exactly what I wanted. I have no footswitch, so no way to switch sounds.
Tried Blackstar direct into computer and it’s lacking something.
What works for you guys?
Check out this guys vids ..
Get a second hand POD.
If you like the "in the room" sound of the ID60 then that is probably the way to go.
The goto mic for guitar cabs is the SM57 which can hardly be described as "amazing" !
From what I read about micc'ing up cabs. peeps tend to be a bit too loud and a bit too distorted.
Spend Sat' reading THE best treatise thus far on recording electric guitar in Sound on Sound Aug 07.
But! You have to know that this is always going to be tricky!
Dave.
You do have to get a decent volume for a '57 to be effective.
Listen with headphones or put the cabinet in another room and listen to what the mic is hearing. Move it around before touching an eq. Closer mic night need a bit of reverb to bring the sound to life, depends if your room sound is okay. Little bit of 300ms delay can work wonders.
