Here's a curly one. As I usually do all the work in promoting my band with little help from the regular band members who, i feel, just want to turn up, gig, take the money and go home. I've come to the conclusion that I may as well use Deps for any future gigs. I'll write the set list and give it out to any deps that can/want to do the gig etc.
Is this a common situation with other bands out there i.e. just use deps for gigs? Does it work? Can you expect Deps to come to a rehearsal before the gig etc?
As for rehearsals...you may find some folk will expect to be paid for their time for this. We use deps occasionally and have never had one rehearse with us, FWIW.
In terms of tightness, well @monquixote is right, of course, but you can still get very good results. One thing I do find is that it's only when you play with someone new to you that you realise how different from the original your version is, and then you notice all the little quirks of your own you've put into the songs without even realising it!
For some musicians the notion of turn up, play, get paid, go home is ideal. For others they want something of the band experience. I can't say that the thought of me effectively as a solo artist with hired hands each time is very appealing, if only because I don't think I know enough musicians!
If you are doing most of the running of the band, I would say it may be time to renegotiate the way the band's money etc is split. If they want to just do the gigs and none of the behind-the-scenes stuff, you could ask them to allow a certain percentage above and beyond their cut to cover running/ expenses/ etc. If they say no, they either (a) start pulling their weight or (b) lose their gig to deps.
It's an issue that has been raised in my band a couple of times, in that there's one guy who does a lot more of the donkey work than the rest of us, in terms of organising etc. Fortunately, for the most part the rest of us have clearly defined roles that also take up time/ effort, so it balances itself out (for example I am one of two drivers, I sort the chord sheets out, the DJ music etc) but if that were not the case I'd certainly agree that if someone puts more in, they should take more out - within a reasonable framework where we all get what we're due.
I only ever dep with one band but when I dep, I get £150 plus usually a bit towards fuel if it's a not local..a little extra for later gigs (1am finish usually means £180...not a fat lot extra but a token amount to show respect for the fact that a wee more is involved).
Likewise our deps get the same, usually a bit extra for fuel, depending on the travel arrangements/ distance.
..followed by a swift change of subject and it's not spoken of again until the following January.
Manchester based original indie band Random White:
https://www.facebook.com/RandomWhite
https://twitter.com/randomwhite1
