Thanx ICBM I thought it would be ok... It's a JCM 2000 DSL btw from 1998
Have to admit I'm no tech with amps but I'm really interested about what you said about running on two valves. I've always worried about blowing a valve at a gig and so the band carries a spare head. I have heard people talking about running a 100 w as a 50 by removing two tubes but thought this must surely damage the amp...So you're saying if I was using my 1960A which is a 16 ohm cab if I lost a tube I could (switch off first obviously) remove the dud tube plus any other (?) then re-set the ohm on the amp to 8 and that would be ok?
If so that's very handy to know
