Harley Benton PB-50 '51 P bass
  • 5redlights5redlights Frets: 317
    Not as chunky as a proper 50's neck, but close enough and what you'd expect for a P-bass neck. The neck is actually quite nice considering the cost and better with a bit of fret work.
  • Perfect. Thanks for that.
    The neck on my Te52 is surprisingly wonderful too.
    I'll see what's out there second hand too, but this is definitely an option- as I said, you've done a lovely job.
    I think there's one of these basses on ebay now actually. I don't think it's being advertised as a Harley Benton though, so you may have to do a generic "bass guitar" search to find it. It was on there a couple of days ago when I was bored and scouring ebay for projects/bargains.
  • reynomeyerreynomeyer Frets: 3
    edited August 2015
    Hi 5redlights, very well done! I modded a HB PB 50 too and because of the slightly less characterful sound I changed the pickup to a Seymour Duncan Quarter Pound single coil. I guess this could be something for you as well. Now the bass sounds really present and pushes like hell. I also changed the pickguard to a white one because the sunburst precis from 1956 were only delivered with this colour. The original Fender pickguard doesnt fit to the HB, so I fretsawed it from a sleeve.
    Here is the result:
    Body: https://db.tt/QXIVsIDR
    Neck: https://db.tt/NJED8Dnl
    Complete: https://db.tt/b7QvCqaK
    The Fender decal is from a good friend who unfortunately died a very sudden death three weeks ago. The bridge and pickup covers and the roundwound Fender strings are from Thomann. Now the bass is perfect to me.
    Kind regards
    Reyno
  • MossMoss Frets: 2409
    edited August 2015
    That looks amazing @reynomeyer
    Stop crying, start buying
    edited August 2015
    Thanks, Moss. Meanwhile I prefer this bass to my 1978 Fender Preci. The original has an ash body and is really heavy. After 1 set on stage you have a postural deformity. And a bump is not really a drama for this bat.
    Lovely job @reynomeyer, looks very authentic. Good news about the SD pickup too, as that is something on my mind given the lack of character with the wilkinson pup.
  • @reynomeyer That's really good too!
    What did you use to treat the neck? Does it have some oil on it?
    Having seen what you've both achieved from a relatively inexpensive starting point definitely isn't helping my GAS!
    edited August 2015
    @5redlights: I am sure you willl be very glad with the SD QP because this pup delivers what the Wilkinson does not: dynamic, a fundamental low frequency spectrum and very silky high frequencies. The Wilkinson sounds a little too tinny at high frequencies.
    @stimpsonslostson: The neck was only treated with a fretsaw for the headstock, sandpaper and matt clear coat for the cut surface and to fix the decal. The rest was sweat and a lot of smoke.
  • So I pulled the trigger & I now have a PB50.
    I like it. I totally agree with your reviews: it's already a nice guitar, but some (relatively minor) modifications will make it even better. I particularly really like the thumpy tone it gives.
    I'm gonna reshape the headstock, replace the bridge, wiring & pots (I have some CTS 250k pots and a Wilkinson brass saddled bridge in my box'O'stuff), add a new pick guard & probably bridge & pickup covers.
    I'll probably start my own thread soon!
  • Nice work.
    Thanks to the magic of the Thomann voucher scheme and the deko instruments they sell I just snagged one of these for £8.80 delivered. Hoping its going to do the job as my emergency backup bass!
  • @oiforlife do you have a link to the right black screws to buy?
  • Excellent bass. Well done!
    Quick question. I was thinking of getting a white scratchplate my Harley Benton PB-50 '51 P bass.
    Eg:
    Thomann - Fender Pickguard WHT 1-PLY '51 P Bass: http://www.thomann.de/gb/fender_pickguard_wht_1_ply_51_p_bass.htm?sid=054c89294042e85d42eca4b0d114f19f
    http://www.stringsdirect.co.uk/parts-c4/pickguards-c106/bass-pickguards-c387/fender-7-hole-mount-classic-vibe-50s-precision-bass-pickguard-p9408
    Do you know if there is a standard fit for 51 P bass scratchplates.
    Many thanks! and well done!!
  • @Eltommo I don't think a fender guard will fit. Someone else on here did one & had to custom cut one. Scratch-it could do you one, you email a scan of the guard, tell em what you want it to look like & they do the rest.
  • Winny_PoohWinny_Pooh Frets: 7788
    edited December 2015
    @reynomeyer
    I played a CIJ 51' for years as my main bass and had the stock pup and hot SD in there but found a wide GFS rails pup to work the best of all. Since selling the bass, its sitting idle in my parts box and I can send it to you to try if you like.
  • @Winny_Pooh
    Thanks a lot for your kind offer, but I am really satisfied with the SD Quarterpound pup. Together with a slightly overdriven Orange Amp this bass growls like the one of Dusty Hill from ZZ Top. And this was my intention. Up to now nobody realized the fake, I added a serial number and a Fender custom shop decal.
    @Eltommo
    The standard Fender 51 P bass scatchplate will not fit, you will have to fretsaw it from a sleeve. But this is not really a problem, it takes less than one hour if you are patient enough.
  • dellludelllu Frets: 0
    It's actually a very good position for the pickup, as it puts it in the sweet spot for a good mix of low end punch and but without the muddiness you can get from neck pickups, and high end clarity. They split the pickup in 57/58 to the standard P bass pup because of the hum the 51 single coil style pickup used to create.
    I agree, as far as a fender style headstock goes, the HB headstocks are actually pretty good. With this one I wanted to get a 51 style look as much as possible.
    Managed to get the headstock done this weekend. Here it is for prep -
    And finished! As you can see, the 51 template just about fitted in, so just needed a tiny bit of sanding to smooth it out, and now it's ready for spraying this week.
    Soldering iron managed to die just when I needed it, so another ordered and wiring to be finished this week. I also went to cut the pickguard from the white pearloid sheet I had, and realised that the pickguard sheet was guitar sized, so not big enough. Annoyingly this means I'll have to leave this and save it for another time.
    can u help me whit the headstoke p telebass 50 shape ? from where i can get this martice ? tnx
  • sunray757sunray757 Frets: 0
    Quality job that.  I have the same bass and want the headstock cutting/shaping.  Recommendations anyone?  Not a job I want to try myself!
  • KoaKoa Frets: 120
    I found a template for the shape online, printed it on standard 80 gsm paper then cut it out. Placed it over the headstock and drew a pencil outline. Cut easily with a fret or coping saw sourced from Screwfix. A bit of light sanding and that was it.....remove neck and tuners to make it easier although the neck pocket is tight so go easy, I chipped the finish on mine.
    Nice instruments, I put a real '69 Tele bass pickup in mine then changed back to the original Wilkinson pickup which is actually very good.
  • FunkfingersFunkfingers Frets: 14532
    @5redlights Excellent work except that the three-tone sunburst finish and 1957-style bridge cover plate look out of place.
