159 bulbs for Badcat amplifier
ToneControlToneControl Frets: 11896
edited March 2015 in Amps
I need some replacement bulbs, I can't seem to find any Uk stockist
these are the wedge-shaped ones 6.3v, run off the heater circuit
any ideas?
  • ICBMICBM Frets: 72339
    You might find something like this from a car parts supplier - things like this are often used for fittings & dashboard lights etc. Even if they're 12V they will probably work fine, just slightly less bright, and last longer - I always use 12V bulbs in things like Fender jewel lamps for that reason.
    There are some that are 6V as well, although they don't look identical - http://www.ebay.co.uk/itm/WEDGE-BASE-CAPLESS-DASHBOARD-BULB-6-VOLT-6V-1-0-WATT-1W-P284-284-x-10-/290674742114
    Stupid design to be honest. I'd probably replace them with a white LED and a resistor and be done with it for good...
  • ToneControlToneControl Frets: 11896
    thanks, I wondered about using LEDs too
  • jpfampsjpfamps Frets: 2734
    Matchless amps used the standard Fender bulb.
    Are these different?
  • IvisonGuitarsIvisonGuitars Frets: 6838
    @ToneControl I got mine from a jukebox parts supplier, there are used in jukeboxes and pinball machines, was about 2 quid for 10 as I recall, I'll see if I can find a link...
    http://www.ivisonguitars.com
    (formerly miserneil)
    http://www.pinballheaven.co.uk/shop/pinball-heaven/259-555-wedge-base-10-pack-wms-p-n-24-8768
    Here you go, my Black Cat has 555 bulbs in it, 6.3v 250mA. They should work fine in the Hot Cat, will just be a bit brighter. Only downside was there is a £5 minimum order so I had to order a set of PacMan fridge magnets too....went down a storm with my little lad!
    The previous owner of my BC had 'modified' the holders and wedged a screw-in build holder into the original spade holders and taped them in so he could use more readily available screw in bulbs....one way around the problem I suppose!
    thanks!
    edited March 2015
    yes, no base, just glass
    edited March 2015 tFB Trader
    Ive just been into the workshop to see if I could find the spares to send you, save you having to make up the order but as usual, just when you want something, it disappears into thin air! :x
    thanks,
    usually happens to me when someone buys something from ebay and it takes me 3 hours to find the manual
  • MossMoss Frets: 2409
    I thought bulbs was another word for pounds  :x
    Stop crying, start buying
  • RockerRocker Frets: 4982
    I thought you were offering an amp as a swap for a lot of bulbs.....
    Nil Satis Nisi Optimum
    Useful to known. I've not had a Badcat in for repair recently.
  • pmgpmg Frets: 298
    Forgive me but what are these bulbs for? The logo light? Is this only for older models?
    2003 model, the logo light
  • FelineGuitarsFelineGuitars Frets: 11594
    I would wonder if it was a standard 12V auto bulb running a bit dim on the 6.3 volts as it looks just like a side light bulb for many cars and it looks just like the sidelight bulbs i have to change on the girlfriend's Honda...
    Take the bulb with you into Halfords and see.....
    Does the logo not illuminate on your Classic Deluxe @pmg?
  • pmgpmg Frets: 298
    Yes...as it does on the black cat. The bulbs look tiny on the plate
  • pmgpmg Frets: 298
    Another example of badcat's excellent customer service
