I stuck some on a Strat I once owned, and it sounded just as good after as before.
I went through a period of busting strings quickly, when I first started playing live. I don't know whether this was due to nervousness and hitting the strings too hard, sweating more or just not having as good a technique as I have now.
I don't often break strings now. Until this last month I was only taking one guitar out with me, and I don't hold back with big bends or vibrato.
I put a sintered steel saddle on the high E and titanium/unobtanium bent saddles on the others.
On a vintage RI strat, for me, NO. I believe that the whole vintage tone comes from the bent steel and spring and block. Remove the saddles and you change the chime.
The Callaham block is brilliant, mind you.
Instagram
To follow on from what I said earlier.
I don't have any on my current guitars, and don't intend to. I just don't need 'em.
The guitar is a '94 American Standard - so it was fitted with 'block' saddles from the factory.
The piezo saddles definitely dulled the 'zing' from it - which as its used for slide - which can sound a bit strident - or as a midi controller, is fine.
If the OP is after 'vintage' Strat tone, Graph Techs are not the way to go.
Instagram
