Joyo PXL Live/Strymon Favourite question?
Bron_Yr_AurBron_Yr_Aur Frets: 99
Can anyone cleverer than me tell me how I can use the two triggers on the Joyo PXL Live as a 'favourite' switch for my Strymon El Capistan please?
I've watched the video manual where he uses an insert cable to change amp channels/reverb etc. but can't for the life of me get it to work with my Strymon, which just uses a latched TRS connection as far as I'm aware...
I'm sure it can be done?
Ta.
  • monquixotemonquixote Frets: 17648
    As far as I'm aware no.
    This was one of the contributing factors to my selling my El Cap and Flint.
  • As far as I'm aware no.
    Arseburgers.
    I love my El Cap, and can't really be bothered with the hassle of midi and Timelines etc...
  • Shame. I use this feature on the Flint (via GigRig G2) all the time and it's so handy.
    You've tried using a mono/mono to stereo jack cable (ie a Y-cable) from both the relays to the El Cap, is that what you're saying?
    Nothing to be scared of with the midi/Timeline FWIW, extremely simple and reliable...
    Indeed. I got RobKabl to make me a lovely right angled Neutrik one and everything. I've set the triggers to latching and tried both polarity settings but it just doesn't seem to want to play ball!
  • steamabacussteamabacus Frets: 1266
    There doesn't seem to be much more than an LED and a resistor in there...
    ... although in series on an SPDT switch ...
    You should be able to make up a lead with a suitable LED/resistor built in under some shrink wrap.
  • AbandonMuteAbandonMute Frets: 29
    edited April 2015
    You've set the El Cap up for use with a favourite switch right?
  • hotpickupshotpickups Frets: 1822
    Midi, Strymon and disaster area's products are a piece of piss to use. MIDI makes life so much easier :)
  • @steamabacus I don't think it should need the LED or resistor as it's just an indicator, and that's all in the Joyo switcher.
    I have indeed, but good question. :)
    *Browses FX classifieds (again)*
    Actually, MIDI functionality was the main reason why I sold my El Cap for the Timeline. Otherwise if the El Cap had the MIDI function included I would have kept as it's a great pedal
  • Well I think I've tried everything now, so it looks like a Timeline for me... :(
    Thanks for your help anyway guys.
  • cbellangacbellanga Frets: 572
    Would it be related to the way strymon use the poles? Afaik it should be tip/ring & tip/sleeve.. While the Joyo could be sleeve/ring & sleeve/tip ?
    Maybe if you try reversing the poles at one extremity of the cable to match that?
  • Bron_Yr_AurBron_Yr_Aur Frets: 99
    edited April 2015
    Worth a go! Will report back. :) Before I open up your lovely cable @RobDavies, would you have any ideas? Also thanks as always for the fantastic cable, service, and postage refund! :)
    Any luck on tinkering with the cables?
    I'd appreciate some feedback on this as I've picked up a Sunset recently n would prefer some smart cabling or intermediary switching that would effectively simulate the switching action of the Strymon favourite -anyone ?
