Way Huge Saucy Box
I'd heard great things about this so I got hold of one to give it a try. I have built lots of klones in the past and I had heard that this is a klone. It isn't.
A few points that I noticed:
-It shares the dual gang gain control that gradually blends the clean and dirt together in varying ratios but apart from that it's not so similar.
-It's a VERY natural sounding overdrive. It is very transparent, and dare I say it, amp-like and hardly colours your amp sound at all. More than any other pedal i've tried it really is like just adding more more more to your amp. It'll go all the way from clean to fairly crunchy (AC/DCish).
-To my ear it sounded a little smoother with single coils that humbuckers which isn't always the case in my experience.
-It's definitely the most touch sensitive pedal i've ever played too (and i've built about 60 of the most boutique circuits out there). Even at max gain you can go from clean to full on crunch just by playing gently then digging in.
-It has a beautiful 'chime' when set to just breaking up than many other pedals i've played just don't get.
-One of the best things about it is the ranges that the knobs have. They are perfectly chosen. Some pedals have way too much volume on tap. On this pedal the values are all sensible so that minor adjustments are very easy without going overboard. (I have a suhr koko boost which is the best sounding boost pedal i've ever played but it has so much level on tap that it's really hard to set perfectly and adjust because the tiniest adjustment does so much.) Because of this its easy to give a flick with your feet to add just a touch of volume etc.
-One of the most unique things about this pedal (having built over 60 various overdrive circuits) is how independently the volume and gain controls work. Usually with an overdrive, if you increase the drive you need to lower the volume a little and visa versa. Not so with this.
from the bottom of the gain control (no dirt) to the max gain there is actually very little in difference volume wise. There is a little volume boost but nothing like most pedals. This is actually a brilliant situation because it enables you to adjust the gain control with your foot should you wish and it won't need any other knobs tweaking. It also enables you to find the sweet spot perfectly for whichever amp you are using because you can dial up the volume to push the front end as much as you want and then subtly dial up as much hair as you want dirt wise. Overall a brilliant new overdrive that really does seem a little different than everything else out there. Did we really expect a Klone from Jeorgy boy? Of course not, and he has again come up with something a little special and set apart from the field.
Though I didn't actually need this pedal for my rig i'm glad i tried it and i've certainly got a hankering to try more Way Huge stuff now. (this was my first). If anyone has a Green Rhino available let me know. :-)
https://www.thefretboard.co.uk/discussion/57776/handsomerik/p1
