More for interest than anything else, to be honest, as I've formed mine.
I was completely convinced the finish made no effect on the sound of the guitar whatsoever. It just didn't make sense. My LTD has a thick finish, but it's lively, resonant and sounds the ballz.
Then I built a partscaster and Wudtone'd it.
Acoustically, it's crazy loud. It's a fairly heavy swamp ash body, but it's amazingly lively, and it really comes out through an amp, too. It even feels nicer to the touch! I've since compared epi LP's to Gibson ones, and have reached the same conclusion - in general, the Gibson ones sound better, even when the epi has the long neck tenon.
Poly can also be wiped on thin, and I have tried another home partscaster with a thin poly and it looked stunning and sounded great - again, acoustically, it was louder than a 'normal' telecaster. And that's saying something... Poly finishes also lend themselves to that super posh 'mirrored' look, though I don't know how thick it needs to be for that...
So, what are your thoughts? I'm completely open to all this being in my head - I don't mind at all
it'll never put me off buying a thick poly guitar (again, the LTD is a corker) and my partscasters will always be wudtone because it's easy and looks amazing (and I'm sure it sounds better for it...). But I'm just intrigued as to how others feel.
I'm not convinced it makes an audible one when plugged unless it penetrates the wood to such an extent that it interferes with the "inner vibrations" of the body. B-)
There's the Adam Jones propelled story that the silver sparkleburst Les Paul Custom sounds different to any other Les Paul due to the finish material. Lot's of fanboys buy into it and it has sent people on crazy missions to find a sparkleburst finish because regardless of talent etc it will make you sound exactly like him.
In reality, and with so many variable in a guitar's design, I doubt many people have had a chance to do a side by side of exactly the same spec guitars with different finish. I am open to the possibility, especially acoustically but plugged in I would put it quite low down the list of effective factors on sound.
Maybe their vibration is unchanged, or not sufficiently changed to be audible, but acoustically amplified differently. B-)
Some of the effects I was hearing might be a reaction to the quality of my work or the way I'd put the neck/bridge back on but I'm convinced there was a difference and I make a point to try to use as little paint as possible now.
Ah, beer o'clock.
The thing I notice most is it doesn't seem to matter what the hell you cover a guitar in, Billy Gibbons still seems to make 'em sound good.
Instagram
as you've had to turn up anyway.........
