I normally don't like "help me pick an amp" threads...
Si_Si_ Frets: 384
However.. I can't decide between a Mesa Mark V Head, or a CAA OD-100.
Anyone use both and can give a comparison? or even opinions on each individually.
  • vizviz Frets: 10707
    Get an Axe FX II.
  • What do you want from an amp?
  • Si_Si_ Frets: 384
    I want a good rock amp, 2 channels minimum, FX loop.
    Problem is both we good deals and both are good amps:(
    edited October 2013
    Honestly still think that s/h EVH 5150 iii 100 watter is worth a look if still at Richtone. PS Coda had 2 halfstacks at one point and were willing to split a head for about a grand when I asked a while ago. You could send those back via distance sellers if they're not what you're after. If they are you could save yourself plenty of cash over a Mark V or CAA
    Yup, I'd go 5150III. Actually I even have a bit of a boner for the 50-watt version right now, but likewise with the Kemper, cannot really justify it!!
    Fuuuuuuuuccc--
    http://www.richtonemusic.co.uk/products/evh_5150_iii_hd_100w_tube_amplifier_head_2nd_hand.asp
    That is a good price. I'd jump on it personally.
  • Si_Si_ Frets: 384
    The EVH just doesn't appeal for some reason.
    Is it the whole "metal" perception??
  • ddloopingddlooping Frets: 325
    Kemper. :)
  • Si_Si_ Frets: 384
    It's the branding I think, I have an EVh guitar and phase 90 don't want to start looking like a fanboy
  • Why not go all out and get one of these bad boys!
    http://i1001.photobucket.com/albums/af135/roscoe2911/117416_16427_zps712991b8.jpg
    In all seriousness, there is a normal version of this with a shit name but a monster spec. Would love to try one.
    Understandable, but I still think it is worth a look by your requirements.
    To play devils advocate - you could possibly remove the badge (the one on the cab I have is attached by allen screws and maybe a spot of glue).
    Furthermore, you could return the EVH head to Richtone/Coda and get a refund if you didn't like the tone.  If you buy a Mark or CAA privately and don't like it you've got to sell it privately yourself, which is often hassle at the high end of the price range (less buyers!).  You've tried a Mark V so know what to expect but a CAA purchase would be near blind in comparison.
  • Si_Si_ Frets: 384
    I only spent about 15 mins with the Mark V so not really a good test.
    I'm rather rubbish settling with an amp so I'm expecting to need several weeks to get used to whatever I get.
  • CatthanCatthan Frets: 364
    Iirc you re at Ncl? There was a evhiii 50 and 1-2 OD variants at guitar guitar when I was there on Saturday. They got mesas too but don't remember which ones.
  • octatonicoctatonic Frets: 33806
    CAA, definitely.
    I have the 50 watter and it is the best amp I've ever owned- and I've owned some killers.
    The Mark V is great and I would like to have one but they take longer to pull sounds- the CAA is quick, closer to set and forget and closer to the Marshall tone I know you love.
    It does modern tones as well- feedback and presence on the back control the amount of 'vintage/modern'.
    The 5150 III 100 watt is great too.
    I prefer the CAA to both of these.
    Kemper. :)
  • ThePrettyDamnedThePrettyDamned Frets: 7489
    edited October 2013
    6505+ head. Only 2 channels, but has 'crunch' on the clean so effectively 3 channels with clean and crunch sharing EQ.
    Or the CAA.  :) Only because I've never played one, but they're nice to look at... The Mk V left me underwhelmed and overwhelmed all at once - it'd be worth spending a lot of time with it.
  • Si_Si_ Frets: 384
    octatonic said:
    CAA, definitely.
    I'm not sure the OD-100 Classic can compare to your PT-50.
  • John_PJohn_P Frets: 2750
    I'd vote for the EVH too - I've had a lot of amps and it's a very very good rock amp but if you really want the mesa or caa then for me it would come down to how you would use the channels.  I think the CAA sounds slightly better (for what I play) but the mesa is probably flexible - if you can really live with two channels get the CAA if you need 3 or more channels then look elsewhere.
  • stonevibestonevibe Frets: 7157
    Only issue with Mesa amps I find is that they are a pain to dial in usually. Too many knobs is their thing.
    But seriously I haven't tried the Mark V myself, so my opinion is only based on experience of their older models.
