Yep Im doing it and it sounds great and is easy to do
my setup goes like this....Amp into palmer PDI 09 or PDI 03 which splits into two signals
first is speaker through into a 4x12 cab for the dry and the palmer then splits into xlr speaker emulated signal into an eventide H3000 then eventide goes into an Art SLA 1 poweramp which then feeds 2 tiny 1x12 marshall cabs for wet wet
so I have my 4x12 as center cab dry and the two little 1x12 as the two wet cabs and the 1x12 cabs are 150 watts each , its great fun and takes a couple of minutes to set up
an eventide H3000 is great for doing this but its the priciple upon which the WDW system works that is important and not the processor.
I have tried the same system just using a boss delay pedal and although it is obviously limited to just the delay because the correct method is used that simple pedal sounds bloody amazing !
for me at least the key parts to the system are a speaker emulator into the wet device and then the wet device MUST go into a solid state poweramp , I tried several tube power amps and tubes do not work properly for me for the wet signal
when done correctly the wet signal should be completely indistinguishable from the dry signal a perfect mirror image if you like and a solid state power amp is hi fi and reproduces that whereas a tube power amp is running the signal from the processor and squashing it with slight tube gain and tube compression and the wet signal ALWAYS ends up sounding different to the dry signal
I want my dry signal tone completely intact and my wet signal should be exactly the same sound /tone and palmer into processor into solid state is the best way I have found of doing it
also in terms of space a Palmer PDI 09 is only tiny it is the size of a foot pedal and the ART SLA1 poweramp is a 1 u rack so you could do this setup with a 1u or 2u rack and 2 small 1x12 cabs which is not taking up much space really . plus it will not break the bank I think I paid £70 for my palmer PDI 09 and £90 for my ART SLA1 used . Then... all that is needed is a device for the wet signal
