The Irontone Standard Edition takes what is already a pretty sweet wah pedal and makes it just that bit better. We alter the sweep and the sound of the wah to give a much more vocal and even sweep from heel to toe. The ‘problem’ with the stock Crybaby is that it has a lot of top end and not a lot of lower mids in its sweep range. Our mod alters this to give a smoother sweep but also retains that high end in the toe position.
A warmer, more vocal sweep with a powerful midrange.
"Absolutely LOVING my Irontone modded wah! All the problems and annoyances of the original design have been addressed, resulting in a pedal which, in my opinion, easily sits up there with the £200 units.” –NickGuitarify
CRANKED COMBO
The Irontone Cranked Combo (or ‘CC’ for short) replicates those classic 1×12 combos cranked to breaking point. The gain is pretty much set and the knob controls output volume only, there is a lot of volume on tap and cranking the dial will result in more hair and compression from your amp.
The CC is very responsive to the signal it is seeing and thus very interactive with your guitar’s volume control. The pedal will act just like a cranked amp, set your guitar volume low for ‘on the edge’ break-up sounds, wind it up and achieve those amps-on-the-edge-of-explosion sounds we all know and love.
The CC also works as a great lead boost and drives already crunchy amps into warm, fuzzy territory.
There's stuff on the site but i'll try and get them converted onto the forum tomorrow.
Thanks man.
The problem is I am then selling on a used pedal which comes with its own unique set of problems. I have done it before though I ended up keeping the additional modded wah.
____________________
www.adamironside.com
www.youtube.com/Adji87
CRYBABY STANDARD:
