G Major scale: G, A, B, C, D, E, F#, G
G Major chord: G, B, D
On a piano it would be a simple construction process as the notes are consecutive.
On a guitar however you have to consider the note positions on each string.. again using the examples provided above..
6th string - G major barre chord fretting would be 3-5-5-4-3-3 (low E to high e) but consider the actual notes being played.. G-D-G-B-D-G. All the important notes appear, taken from different octaves, and often duplicated, that is the beauty of guitar.
One of the nuggets I like is that this position the 5-4-3 middle section (partial chord) of the entire barre chord, best reflect that of a piano's chord voicing... handy to know if you wanted to emulated crude piano chord work.
Learn the root, 3rd, 5th
Learn every note on every fret.
Sorted !
Example:
C Major scale
C D E F G A B - C D E F G A B C
C E G = C Major
D F A = D minor
E G B = E minor
F A C = F Major
G B D = G Major
A C E = A minor
B D F = B minor (b5)
A-shape chord have theirs on the 5th string
Once you have nailed the majors and the minors, consider the 7th-type chords
I maj7
ii -7
iii -7
IV maj7
V7
vi -7
vii -7-5
not as scary as the nomenclature looks, and the A-shape fingerings are surprisingly easy.
Try also D-shapes (root on 4th string)
It can however help to associate a practical chord shape with a given arpeggio pattern or one of the 5 pentatonic patterns or one of the 7 shapes of the 3-note-per-string scale patterns. EG the e-shape minor chord shares a lot of notes with the minor arpeggio with its root on the 6th string, shape 1 of the minor pentatonic scale, and the lower part of the 3-note-per-string pattern for the aeolian mode (natural minor, 6th mode of the major scale). The latter takes you a little out of position on the upper strings, but I'm sure there's probably a classical guitar equivalent that doesn't (probably by playing only 2 notes on the G string).
