Here are some snaps of the prototype of a 100W guitar/bass head.
The initial motivation for this amp is that I wanted my own bass amp. At the moment I am using a friend's Bassman 100, and I expect at some stage hoe will want it back.......
I wanted to try to produce an all valve 100W bass head in a relatively compact package, that will have something of an SVT vibe.
Although this amp was initially designed as a bass amp, we've had some interest from a couple of guitar players, so there will be a guitar version as well.
The amp fits in our "standard" headshell, and will weigh in at around 14 kg.
For the more technically minded here are some of the amps "interesting" features:
- Same treble/bass control topology as our other amps
- Defeatable active mid cut/ boost using a tapped inductor a la Ampeg, which gives 5 selecteble frequencies to cut and boost.
- Fixed bias long tail pair phase inverter driven from a DC coupled cathode follower
- 2 x KT88 giving 100W output power
- Unlike our other amps we've employed negative feedback around the power amp, so we can have a conventional presence control
- Toroidal mains transformer to reduce hum and save weight (this will be potted in a production model)
We've got a few issues to sort out with this amp. The primary loading is a bit on the low side, we used a 100W transformer that we had knocking about (this often happens when prototyping....)
The HT is a bit higher than I would like (740 VDC, 370 on the screens), which is OK for KT88 but too much for 6550s, and I would like to have the option of using either valve in this amp, so we will need to adjust the windings of the mains transformer. Ideally I would like around 680 on the anode and around 380 on the screens.
Anyhow, here are the photos:
The front (sans control panel). We're aiming to use some different cosmetics on this amp, but I wanted to weigh it in a head shell. We'll also incorporate a vent in the top of the headshell.
The back. Bias test points, and outputs for 4, 8 and 16 ohms. This is what the transformer we used had, but this can easily be user defined.
Mid control inductor. Wound by Sowter. Note the mu-metal can for low hum.
Finally some gut shots, and yes Dave there is no insulation on the mains inlet/ switch (yawn).
Lol!
