A note over A# chord
Was doing some writing with the band last night and the idea was in Dm which contains both A and A#. At one point I was playing an arpeggio containing an A (13th fret B string) whilst the bass player was playing an A# and it sounded fine. Surely this shouldn't have worked?!
  • CirrusCirrus Frets: 8491
    edited October 2015
    No reason why not - as long as they're at not at the same octave (ie within a semitone of each other) that's a perfectly musical interval, and a key component in a major 7th chord.
    Although... wouldn't the 13th fret on a string tuned to B be a C?
    very interesting thanks! my music theory is limited and I always assumed that playing notes a semitone apart was a no no!
  • Ah sorry complete brain fart, of course it is!
    edited October 2015
    Well, two notes a genuine semitone apart does sound quite clashy, although it can be a very powerful musical tool - try arpeggiating this chord slowly on the thinnest four strings;
    E-0
    B-6
    G-5
    D-3
    Generally, the lower the semitone clash is the more muddy it'll sound. But in a chord like that, the F at the 6th fret of the B string and the E on the open string can be used to create tension and a sense that something needs to resolve.
    What you're both playing is way more than a semitone though. If the bass is playing an A# on a lower octave, say the 6th fret of the E string, it's three full octaves below an A higher up on your guitar's B string. Obviously it depends on the musical context but there's no reason that couldn't sound very musical - because the notes are so far apart they won't have many clashing overtones.
  • The bass player was playing a Bb. Your A, combined with other instruments' D & F would have made Bbmaj7. Lovely chord in the key of Dm :)
  • It's not so much the journey but the destination.  If you resolve to a strong chord tone you can play anything.
  • moz91moz91 Frets: 38
    edited November 2015
    If you're in Dm then it's a Bb not an A#. Your C would give you a 9th on a Bb major chord, where as an A would have given you a major 7th. Try play a 2 octave Bbmaj7 arp over your bassists Bb but finish on the A. Will sound unresolved but will work and still sound musical!
  • ClarkyClarky Frets: 3261
    this... and of course in the key of Dm, Bb is note VI so it's perfectly within key.. and you most likely have a Bb maj7 going on
