Bugera bass heads?
ReverendReverend Frets: 5002
Thomman have what looks like a copy of an SVT ss head for about £160. Our bassist needs something with -plenty of beef - anyone tried these?
Any thoughts?
  • fretmeisterfretmeister Frets: 24355
    RacerDeth / Vainmaiden / Nick has one.
    Reckons it's very good, really beefy.
  • ICBMICBM Frets: 72411
    Nah… you don't want that… you want… THIS
    http://www.thomann.de/gb/bugera_btx3600_nuke.htm
    Look at the power… and the price!
    I assume they're discounted because no-one bought them. Admittedly finding a cabinet that will handle it could be the problem, although there's no way that power rating can be genuine RMS (… sorry Dave!). The maximum mains input power can only be 2300W because it has a 10A-rate IEC power connector, so the true output can't be over 2000W and probably a bit less than that.
    Still a *lot*of beef, though.
  • ReverendReverend Frets: 5002
    Pulled the trigger on the nuke. The clips sounded ok and for £160 it's a no brainer. As long as it has enough beef to match my jmp 2203 then we are laughing.
  • DLMDLM Frets: 2513
    edited November 2015
    @fretmeister @RacerDeth How the devil is Nick? Does that mean he's still playing? :)
    Assuming you have a cab - or more likely two - that will handle up to 2000W, yes… :)
    Usually will be using svt cabs I'd imagine. Won't be any need to crank this up too high.
  • BucketBucket Frets: 7751
    "The Nuke" is one hell of a name for an amp.
    He's fine! He's playing and experimenting with pickups and he's playing a bit more bass these days.
    And he spends a lot of time painting those tiny die-cast models he likes.
    @fretmeister
    Thanks! If I ever make it over to FB I'll look him up.
  • My dad has a couple of those bass heads (badged Behringer, but the same thing). Both are incredibly good value, though I'd say the Ashdown knock-off sounded better than the Ampeg one. The Ampeg one was stupidly heavy to lift, considering it was mainly empty box though
    The Ashdown knock-off is better made than an Ashdown too!
    Although as jpfamps said, that's perhaps not setting the bar very high… but they are quite decent in fact.
