Hi All,
I could do with a bit of advice.
My current board in this order consists of :
TU-2
MXR DIstortion III
SD-1
Line 6 M5
LPB1
into a laney VC30-112 . Main guitar is a Telecaster.
I am struggling to get a solo/boosted tone I really like.With current set up I use the SD-1 to boost the MXR (on the clean channel) and use the LPB to boost the dirty channel on the amp.
I now thinking that I may be better using the the LPB1 first in the chain to boost the guitar signal.
What do you think?
I don't get chance to experiment with this outside band rehearsals and the rest of the band don't want to listen to me pissing about for 20 mins.So any advice much appreciated.
Ps Thanks to Mike L for recommending the Distortion III and anyone who recommended the M5 a few years back both great pedals..
For a solo boost, try the lpb in the loop. That way, you're taking the same distorted signal and just making it louder.
If this doesn't work, it's a toughie. But think as distortion first, volume later. The mxr has LOADS of volume boost available - so try running the sd1 first, then mxr with gain low, volume up (and the other way around to see what you prefer).
I'd use the SD-1 as a boost, and the D3 as an alternative to your amps drive channel.
So guitar-tuner-SD1-D3-M5-Amp
If you can beg/borrow/steal/acquire an MXR Microamp, put it in the amps loop as a volume boost.
Also, if you can try a Bad Monkey, they work really well as a boost in front of a dirty amp.
DONT put a drive pedal in the amp's FX loop as it can cause damage. (I'm not familiar with the LPB1).
And I'm pleased you enjoy the D3, I got mine untried from Hartnolls, and absolutely love it.
