Ohm math
MosfedMosfed Frets: 25
Ok - can someone help me understand ohm math?  And post a formula?
If I am putting both a 4 ohm and 8 ohm cabs into an amp - what is the ideal ohm setting for the amp that has both 2 and 4 ohm options?
I would guess 4, but?
  • Paul_CPaul_C Frets: 7786
    edited November 2013
    not sure it's recommended, but it depends on how you're doing it - a 4ohm cab and an 8 ohm cab in series is 12ohms, in parallel it's 2.66.
  • bertiebertie Frets: 13569
    MATHS
    I now have to shoot you
    4reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • MosfedMosfed Frets: 25
    I would do it in parallel.  So you are saying put the SVT on 2 ohms?
    Paul - I would really appreciate you posting the formula.  I would love to understand it better.
    I'm not saying anything other than doing the sums for you ;)
    I'd get two 8ohm cabs and set it on 4 :)
    but as bertie's going to kill you I don't suppose it matters.
    :D
    I guess my yank education is shiiiinin' through!
    In series, I get it.  4+8=12
    In parallel, I don't.
    GOT IT!  Thanks Paul.
    That's the beauty of the internet - you don't really need to understand.
    What am I missing?  Why would running 2.66 into 2 be a major issue?  Would it be better to run it into 4?
  • It's the reciprocal of the sum of each element's reciprocal.
    i.e. One divided by (one eighth plus one quarter)
          1
    __________  = 2
    1/4 + 1/4
           1
    __________  = 2.66
    1/4 + 1/8
    Many thanks.
    IIRC, but don't quote me, the difference in the two cabs will mean that you may well find one will be quieter than the other.
    Hadn't thought of that.  Very likely indeed.
  • ICBMICBM Frets: 72339
    It's not. Although it's 2 into 2.66, just to be pedantic :). (The amp is an *output*, the cab is an *input* and hence the amp goes into the cab and not the other way round.)
    You can usually mismatch by up to about a factor of two in either direction with no harm, to a valve amp - and if anything, a low mismatch (cab impedance lower than amp impedance) is less likely to harm a valve amp than a high mismatch. But 2.66 is close enough to 2 that I would use 2 ohms.
    (NB, for a solid state amp, never run a low mismatch - you'll probably blow the power transistors.)
    But not by very much. In some cases with different cabs it can actually improve the balance, if the less sensitive cab is then given more of the power. The power division is 1/3 to the 8-ohm cab and 2/3 to the 4-ohm cab, so make sure the 4-ohm cab can handle at least 2/3 of the total power of the amp, not half.
