Help! Carvin Legacy 1 head. On the 50W and the 100W settings, the volume is sometimes ok, sometimes it drops to half or even less. The transition takes about 0.5 seconds to complete. The tone itself sounds just about Ok - a little more trebley but passable - even when the volume drops. It only seems to happen when the pre-amp is being employed - haven't noticed it when going straight from my vox modeller into the return socket. And when I switch standby on after playing there's a throat-clearing sound. What's the problem?
@icbm,
@ecc83,
@jfpamps and other gurus?
Roland said: Scales are primarily a tool for categorising knowledge, not a rule for what can or cannot be played.
viz said:
If it starts saying "one, two ... one, two" then it clearly has aspirations to be a PA amp. >:D<
It'll be calling bingo numbers next .... :-S
Seriously, it could be so many things wrong with it. I'd try swapping pre-amp valves first then if that doesn't find the problem, see if any of the the control pots have any part to play. After that I'd be calling for the gurus on here, or more likely taking it to ICBM to look it over.
You wouldn't want to spray it on parts of the circuitry that carry high voltages because it's probably electrically conductive, but pots and jacks don't.
