Bandcamp
Spotify, Apple et al
You just need a medium weight slide and some respect for the fact that it's not something that's going to sound good quickly. It needs a) technique which you have to practice hard and b) critical listening on your part to hear whether you're playing in tune.
I've taught slide to a few people over the years and in every case they start off assuming that the reason they're clattering the slide against the frets or have bad intonation is down to action, or strings or slide, or finger picks or blah blah blah. It very rarely is.
My tip is to pick a simple melody (I started with "Danny Boy") and play it on each string individually (change key to be that of the open string). Do it in standard tuning so it will sound horrid if you sound adjacent strings. Work on slide positioning and damping so you can play it cleanly on each string. The fact that it's a really familiar tune will help with your intonation. The fact that you're sticking to one string will force you to damp well and also get your slide mobility working.
Lewy is the resident slide maestro, pay close heed to all he says
That said, if you DO have a spare guitar to dedicate to slide duties (Teles and Danelectros lend themselves to it very well), having one with a higher action in an open tuning will get you up-and-running quicker. Try it fingerstyle as well - and also, listen to Ian Siegal
Just a note that using a nut riser or a replacement high nut is not a cop out, playing dedicated ultra-high action lap steels and Weissenborns (and pedal steels) is a different style to playing an upright guitar with a bottleneck.
You can play a normal action guitar with a bottleneck, but it takes practice, and there is a limit to what you can do and the sounds you can achieve. It is not the same technique as playing lap steel with a bar. You can mix in fretted playing too, which is a good option.
Personally I either play properly fretted guitar style - on a normal guitar, OR lap steel slide-style on a dedicated guitar. To me the tone and harmonic possibilities are far better with lap steel than using bottleneck on a normal guitar
This is a good call - also, if you wear your slide on your ring finger there's some nice 'blue notes' a fret above the slide in certain tunings that you can reach with your pinky.
