(Keeping the root, using Maj and min 3rds, but the treble note increases by a semi tone)
C Eb Gb (dim)
C Eb G (min)
C E G (Maj)
C E G# (Aug)
C E A (Sixth)
C E Bb (Dom)
C E B (Seventh)
C E C (Octave)
lol dunno really, it just seems to work out ok - with the tubescreamer set to 11 anyway.
Diagonal the other way also works because of the augmented 4ths or tritones in melodic minor. Upwards diagonal aug chords that work in a super locrian context (in G) would include:
My YouTube Channel
Hindu (5th mode melodic minor) over tonic chords in place of mixolydian - though strictly speaking this uses a minor 6th rather than an augmented 5th, and the chord is really a suspension rather than an augmented triad.
Lydian augmented (3rd mode melodic minor) also works but is not particularly useful.
My YouTube Channel
My YouTube Channel
With Aeolian, the V chord is a minor triad, so it doesn't deploy the tonic's leading note. If you play in A minor, and for the V you play an E minor triad (as part of a Phrygian scale), you're playing strictly Aeolian music, like they did around the medieval period and before. The E minor doesn't point as effectively to the A minor as an E major would have done. Or to put it another way, the minor triad is not as effective a chord for a dominant. It still works (everything works coz there's no right or wrong in art!) but it's not as effective because G is not as good as G# in resolving to A. If you want a proper V, you need that major triad on E, with its G#. So they discovered and named harmonic minor to describe this effect - it's a harmonic device that gives a sharp 7 in the minor key.
Because it was designed for the major triad on the V, it says nothing about the 2nd note on that V - the 6th note in the A minor. That is assumed still to be a minor 6th, as per Aeolian. And therefore between the minor 6th and raised 7th (or between the unheard minor 2nd and raised 3rd on the V triad), you get an augmented 2 jump, which was thought to be ugly and difficult to play and sing. So hence the existence of melodic minor with its raised 6th as well. The dominant triad still sounded the same, E major, because there is no F or F# in the triad, but for the melody, when playing over the V and leading up to the I chord, you would play a major 2 as well as a major 3, and avoid the aug 2 jump. Of course when you'd resolved to the I chord you'd flip back to Aeolian, which is why melodic minor scale is played as Aeolian on the way down in classical - it only has raised 6 and 7 on the way up, as though it's on the V chord, but after resolving to the I, on the way down again, the 6th and 7th would be returned to their natural, minor, states.
I digress. So harmonic minor was designed solely for the major triad on the V, and even Yngwie (famed for his neoclassical harmonic minor shreddin'), if you listen carefully, only really noodles on it on that V, where it is designed for, so he's actually playing the 5th mode of it. Not harmonic minor but the 'freygish' scale. That's its main use - in fact that's why the freygish scale is also called Phrygian Dominant - and I confess I'm struggling to think of much music that uses any other of the harmonic minor modes.
Whereas because melodic minor is a melodic device, it's far more tuneful and thus far more prevalent in melodic soloing if not for chordal writing. Therefore it's a far richer scale to learn the modes of, as scales:
1st mode: Used often in minor melody, from the rennaisance period to today
2nd mode: combines phrygian start with dorian finish. Very lovely scale.
3rd mode: like lydian on steroids. Difficult to deploy but very spicy when you succeed.
4th mode: contains all the harmonics of a vibrating string. Used in the simpsons tune, famously.
5th mode: as explained earlier, used on the dominant of a minor key; also used a lot in Indian music as a scale in its own right; also try replacing mixolydian with it in I or IV chords. Interesting!
7th mode; used all over jazz on the V. An amazing scale. Every note is altered from the major scale by 1 semitone but it still works somehow!
Of course you can learn whatever you like!!!!!! Obvs. And 5th mode harmonic minor is clearly useful for shreddin' but i think you will find more application from getting melodic minor and its modes under your skin.
My YouTube Channel
http://www.guitaristtv.com/Downloads/Modes 2014_02_18 - for GTV.xlsx
http://www.hooktheory.com/blog/i-analyzed-the-chords-of-1300-popular-songs-for-patterns-this-is-what-i-found/
My YouTube Channel
