Bigsby tuning stability
Any tips on how to tame the B string on my Epihone Riviera? The B string is not returning to pitch if I use the Bigsby to bend down. All the other strings are fine and if I pull up on the Bigsby, it all goes back into tune. I'm guessing the string is sticking somewhere, but not sure how to solve it.
Thanks.
  • ICBMICBM Frets: 72330
    Is it sticking flat or sharp?
    Sharp: nut, or possibly tuner post.
    Flat: bridge saddle.
  • Thanks. It's sticking flat. I'm presuming some kind of lubrication would be necessary? Any recommendations? Anything to avoid?
    Have a close look at the saddle groove - if it's a tune-o-matic type (especially far-east-made) they can develop a burr in the groove, usually on the vertical face, which snags the string. You need to carefully smooth it out with a needle file.
    Lubricating will help too, I use a tiny spot of standard lithium-based car grease. Don't overdo it, not only will it make a mess it will also damp the tone. (Really!)
