Either in some way you have accidentally reversed the phase of the pickup and are confusing the nasty 'cocked wah' sound you will get with being microphonic ... not really very likely. Or, more likely, is that the pickup in question has some issues that disturbing it (by removing the scratchlate, has brought to light.
Unlikely to be a loose cover on a Strat .... but anyway you can always try the pickup without the cover and see.
If the pickup is an old one then loose magnets can cause handling noise and squeal. I've encountered a few from hand winders that have had rather loose outer coils that can cause this too.
It would help to know the pickup make and age ....
It's a Dimarzio Virtual Vintage. Got it ages ago but it's never been a problem. Moved it from the neck to the bridge position and it's all messed up.
Cheers
:-bd
