Lifting Fret
BigLicks67BigLicks67 Frets: 768
I've got a fret partially lifting off the fretboard on my Jazz Bass, it is at the 13th fret and only really causes trouble on the G string. Is the solution to this a tube of super glue and a small wood clamp?
Many thanks in advance for your learned replies.
  • sweepysweepy Frets: 4189
    That's the accepted "fix" yes, you only need a tiny dab of the thicker superglue
  • ICBMICBM Frets: 72486
    You're playing at the 12th fret on the G string, on a bass?!!
    That's both of your problems right there.
  • BigLicks67BigLicks67 Frets: 768
    Outrageous behaviour - I Know. : >
  • Paul_CPaul_C Frets: 7806
    edited March 2016
    I'm not ashamed to say that when I gigged as part of a duo (with a guitarist who played mostly rhythm) and used a Musicman Bongo I more than once was seen to bend up from the 24th fret on the G ( I used very light strings, still do) :)
    I admit to playing above the 12th fret as well occasionally - although in my defence, only on the E and A strings. I use the G string on one song too, although only up to the 6th fret I think.
    I must be getting better at it…
    Anyway, the answer to the question ;) is yes - a small amount of superglue (I would use thinner stuff actually, so it wicks in under the fret better) and a clamp should fix it.
