Soldering Pots ?
is it necessary to roughen the back of  alpha pots before soldering? I've heard/seen yeahs, bet have also read that most pots are pre-tinned (or similar) and sanding would only remove this. What's the word of the wise?
  • RolandRoland Frets: 8704
    I always clean and tin the spot where I want the wire to go.  If the pot isn't clean then the solder won't stick, and if it is uniformly clean then I find the solder spreads out more than I want. Scraping and pre-tinning a small area keeps the solder where I want it.
  • GuitarMonkeyGuitarMonkey Frets: 1883
    edited December 2013
    Give it a go. If the solder flows onto the pot you are fine. If not, sand it back.
    Generally the only problems are with cadmium or chromium plated bodies.
  • I always scratch it and tin. No reason not to, doesn't add much work, and my joins have (so far) been reliable.
  • OilCityPickupsOilCityPickups Frets: 10381
    Shouldn't need to abrade any new pot ... if you have to you tool isn't big or hot enough :)
