Project Tele
Picked up a pine tele body from the forum this week but can't decide how to finish it.
At the moment it's got a couple of coats of tru-oil on it but I'm thinking about the sea foam green colour that wudtone do.
Do you have to sand back the oil finish before applying the wudtone stuff?
  • rprrpr Frets: 310
    Best to Pm @andypwudtone for advice. I've a feeling that sanding wont be enough to remove the oil. but see what the man says..  Green guitars are cool
  • Hi Guys, as long as you do enough sanding your OK, As long as it seems like your back to bare wood( and its just wood dust your creating )  your OK. I've never had any problem with an orbital sander (say 100 grit) on the front or back sorting the issue out in less than a minute, edges take longer may need flap wheel. . Watch for clogging and refresh paper if needed.  Finish sanding with some clean 240 grit along the grain. The Surfer Girl is pigment ( as well as dye ) based so not so critical.
    Let me know if you have any more questions.
    kind regards
