However, everything except the final production and assembly is done in the UK (90% of it by me!). Of course, you need a very good factory too -- which we will be using.
I agree!
The Hotone Wally looper has a cool** tempo function so you can warp what you are looping. But you can't really do that on the fly so manipulation of what you are looping in those kind of ways - tempo, pitch, modulation I guess - doesn't seem to have been explored all that much (although it could have passed me by).
Finally, every new looper should come with an automatic self destruct if the pedal user tries doing a KT Tunstall in front of actual other human beings. Unless it's KT Tunstall, that would be OK. But nobody else, ever...
*I appreciate I am a middle aged man and saying kinda awesome is a bad fit.
**similar bad fit.
Yes. We've had quite a few suggestions of this today since we launched the campaign. Having a remote controller option is a very good idea, though it does increase the cost. For a singer, one of the great things about the Loopa is being able to walk around without being tied to a foot controller... but having the flexibility to do that, or use a foot controller ticks all the boxes!
Yes that's a nice idea.
And, of course, you are right -- it's pointless if the microphone itself isn't good! We're expending a lot of effort to make sure this part is good. Initial testing had very good comments from artists, but the production version will be even better.
I have Maschine for our drum beats and I'd like to plug a looper into it and for the looper to sync up with the tempo of the beats. Somehow.
My issue with loopers is that unless I'm absolutely 100% spot clicking start/stop the loop will start drifting out of time.
If this does that I'll buy 2.
*Note: I can't sing, so I'm not the target audience anyway!
(1) Simplicity - you have a microphone and connect to an amp. No other pedals, mic preamps (unless you have that on your looper pedal), etc, required. It makes it very easy for a novice to start looping
(2) Cost - it's cheaper to build a microphone with a looper inside because you don't need to make 2 products. For a cost similar to a good microphone, you can have a good microphone with a looper (and built-in preamp).
(3) Ergonomics - having the buttons in the right place, and ensuring the microphone rests correctly in your hand so those buttons are easy to press when you need them, makes a big difference to the usability.
