embarrasingly nooby question: hi and lo inputs
McTootMcToot Frets: 2042
What are they all about?
I may have been playing guitar for over 30 years but I've never had an amp with hi and low inputs.  But as of todfay I do.  What's the deal with them?
(It's the Cornford Carrera I got off Mrkj2000 by the way - full NAD thread to follow).
Beauty is in the eye of the beer holder
My trading feedback  - I'm a good egg  ;)
  • The Hi one is the one just above the Low one
  • McTootMcToot Frets: 2042
    Incorrect.  It's to the left.
  • octatonicoctatonic Frets: 33797
    I usually use low input for humbuckers and high input for single coils.
    Depends on the amp though.
  • the_twinthe_twin Frets: 130
    low and high gain
    Always assumed that high was for pickups with a fairly low output, and low was for pickups with a very high output.. essentially a way to choose between two different input sensitivities, and not much more than that.
  • ICBMICBM Frets: 72335
    edited December 2013
    If it's the standard vintage arrangement where both are inputs to the same stage, then:
    Hi - full signal level, high impedance. Brightest tone and most gain.
    Lo - half signal level, lower impedance. Softer tone as well as quieter.
    It's done with a couple of resistors which are connected in two different arrangements depending on which jack you plug into. You can do two other things as well:
    Plug two instruments into both inputs at once - both are then effectively Hi inputs. Also useful if you have some sort of parallel effects path where you want to mix clean with effect.
    Plug the guitar into the Hi input and daisy-chain the Lo input to another amp, or another channel on the same amp.
    There are also some amps (Marshall JMP and JCM800 Master Volume amps, and a few others derived from the same basic circuit mostly) where the Lo input is a lot different and bypasses the first gain stage, giving a much cleaner tone.
    The Carrera is the vintage type, assuming the unofficial schematic I found is correct.
  • Wisdom for that ;-)
    Check out Koss's Marshalls in this vid
    Personally I always use Hi, but I'll give Octatonic's idea a crack.
    "Nobody needs more than 20 strats." Mike Landau
  • Oops wrong vid.  What's he done there Icey ?
  • chillidoggychillidoggy Frets: 17136
    The high input is the 'normal' input. Check out the explanation here for the Hurricane, but I'm guessing it's the same for the Carrera.
    http://cornfordamps.com/hurricane.htm
  • 57Deluxe57Deluxe Frets: 7339
    The Hi and Lo inputs originated in the days when the guitar amp was also used for a microphone input and often (don't laugh) the very popular accordion!
    <Vintage BOSS Upgrades>
  • ecc83ecc83 Frets: 1633
    And then! There is the Artisan series that have four jacks, two per channel and you can feed one across to tother and use both channels for increased tonal effect. Or indeed as a sort of "poor man's FX loop.
    Dave.
    Thanks all.  I very rudely asked a question and then scarpered out to take my wife, mother in law and two daughters for tea (a sort of penance for having bought the Carrera).  No I am back and catching up on this and it all makes sense.
    Don't forget the demo vid you promised, McToot! ;)
  • Dibs, btw :p
    Dibs, btw :p
    Oxblood would look good with a desert backdrop...
    PM'd
