So...I've had a free half hour tester......
......lesson with a local tutor. Where he's advised me about guitar set up...what positions to hold it when playing...left thumb positioning and fretting pressure. Apparently I shouldn't play the guitar hunched over it with the neck parallel to the floor, it should be at an angle towards my left armpit.....and I'm fretting too hard....he showed me a technique to only press as hard as I need to. And changing fretting thumb positions between barre chords and more finger extended chords. Now I just need to find twenty quid for my first paid lesson!!
  • thecolourboxthecolourbox Frets: 9801
    The big question is, a question failed by the two teachers I've ever tried to have lessons with...Did he then try and teach you Stairway to Heaven?
    soundcloud.com/thecolourbox-1
  • The big question is, a question failed by the two teachers I've ever tried to have lessons with...Did he then try and teach you Stairway to Heaven?
    No.....only had half an hour. He might try on my next lesson.
  • BigLicks67BigLicks67 Frets: 768
    To be fair having the neck parallel to the floor is not the greatest of crimes as there are a lots of styles where this wouldn't make much of difference, particularly where the thumb is on top of the neck rather than behind for example :
    Also, I'd question the wisdom of showing someone barre chords in the first lesson.
  • SambostarSambostar Frets: 8745
    The neck not being parallel to the floor or on the left knee only is to save your back in the longer run.
    Backdoor Children Of The Sock
    You could just as easily argue that having the left foot raised by a foot stool in the classical style will promote back trouble, it certainly did for me and judging by the widespread use of devices like the Ergoplay I'd say I'm not alone.
  • Think I will be giving Stairway to Heaven a miss while this copyright mullarkey goes on.
