I built a Vibrolux Reverb recently and the reverb has just died. It's definitely the tank (I've checked the valves and the cable and tried the tank with another amp). The connections to the sockets and transducers appear to be fine, but there's a bit of brown leaky stuff on the tiny input transducer socket. Has the transducer burnt out? If so, what might have caused it? The voltage on the reverb transformer is high (440v I think - can't quite remember) but this is the same as a Pro or Twin Reverb, which use the same value components I think. Any help would be greatly appreciated.
Yes, Accutronics and Belton are now one and the same: http://www.accutronicsreverb.com/
+1 on all that.
I do both a 1 valve and 2 valve spring reverb option on my amps, but for the future I'm also working on adding a digital reverb option using the Belton 'brick'.
It's used in some very well respected reverb pedals (I've got one, a Juansolo job, and it sounds amazing.)
I'm a fan of digital verb and delay. Less noise, better tones (mostly). My bandit has a long spring tank and it sounds pretty good, if a bit bright. It doesn't get clangy until the last quarter of the dial though, so perfectly usable, if not exactly a digitech hardwire.
