New Tube amp- HUM on stand buy, also strong HUM when using FX loop
johnmontanajohnmontana Frets: 41
edited December 2013 in Amps
Hi there,
Is it normal to have a  HUM on stand buy position? When fully turned on, the amp goes a bit quieter than the hum is coming back in few secs....
Also the FX loop have a strong hum noise even when a patch lead connected (no pedals)
Is this stuff common to tube amps or an easy fix  or I should just return the amp?
I am not good in tech stuff so please don't bombard me with all sorts of abbreviations etc...
Cheers!
  • FezFez Frets: 528
    What amp is it?
    Sounds like it's new, is it?
    Don't touch that dial.
  • It is a ZubZero 50w head, yes, brand new.
  • ICBMICBM Frets: 72472
    That doesn't sound right. If it's new, you may want to take it up with the shop, if you're not good with tech stuff yourself.
    Are you powering the FX in the loop from the same power supply as the ones in front of the amp? That can cause a bad hum if the supply doesn't have fully isolated outputs.
  • The pedals were battery powered...also tried with just a patch lead... nothing changed, same loud hum noise
    Definitely faulty.
