Still prepping for my
@GSPBASSES body and neck, which will be around sometime in the new year, but also for my upcoming strat or tele build.
I'm actually, for my tele/strat, going to used a solid finish like T-Bird but I love that aqua a lot, so maybe I'll ask Andy nicely...
Anyway, after several coats of colour, you apply the top coats of Wudtone (several extra thin coats). It's glossy, and can be made to shine, but not mirror. These polishing compounds seem to have really boosted the shine to close-to-mirror, which I'd like.
Can we source anything like Colortone in the UK? He used the medium then fine ones and buffed it by hand.
I tried a walnut strat this year using a great deep raspberry wood dye I found in Spain not seen a colour like it in the UK as I wanted a Walnut strat that did not look like my Nan's sideboard as most walnut guitars look a bit furniture like. I did the raspberry wood dye went on fine then finished with lots of Wudtone topcoat it looked really lush. Left it for a month to fully cure and tried to buff it out with a slightly abrasive compound like colourtone it buffed really nice and got almost mirror like finish the only down side was as there is not grain filling with Wudtone it fills and levels as its oil based itself. Some of the compound permeated through the Wudtone and into the walnut grain leaving with a white residue in the grain below the finish that looked awful. It would not polish or come off so the Raspberry Strat will be down for a start again this year. I imagine this would be better on Alder and I have played with Wudtone on Alder and buffed out to a gloss with a compound.
The best advice with Wudtone is to test on scrap wood if you are going off from Andy's recommendations as you can in my experience screw it up. Also let it cure for a good few weeks.
regards Jez
I might give the wax a go, but maybe I'll see how this one turns out.
